Hi, i am brand new at VCDs and have recently made 5 VCDs that are about 45 minutes long or so, is it possible for me to combine them all together and split them into 70 minute long (or whatever will fit on an 80 CD)? And if so what software would i need, and would any converting need to be done for the vcd files. Thanks alot.
Extract the mpegs from the VCD's, then use TMPGEnc to join them all and then cut them where you want.
Combining 2 Videos into 1 file with two windows?
By 201flyer in forum EditingReplies: 11Last Post: 29th Jul 2012, 07:31 -
Combining MP4 files (h264) with mencoder results in blank (white) videos
By mstaker in forum Video ConversionReplies: 0Last Post: 10th Dec 2011, 14:35 -
Audio sync issues when combining videos from Youtube
By The Invisible Hand in forum EditingReplies: 5Last Post: 6th Oct 2011, 12:43 -
Combining videos with different fps
By michn in forum EditingReplies: 4Last Post: 4th Apr 2011, 06:55 -
Conversion usiing VirtualDub - 720 X 560 videos into 640 X 360 videos
By candyman9999 in forum Video ConversionReplies: 1Last Post: 13th Jan 2009, 22:13
