First off I have tried to do this (divx to svcd) with tmpgenc/virtual dub and I had way too many problems with audio synching![]()
. Now, I have tried to do this with Ulead Moviefactory 2 and it will convert the video all the up to 99% and an error message
will pop up saying could not convert(or something along those lines) can somebody please help me with this. Should I be extracting the audio first and then putting them(video+audio) back together? This has become really annoying. PLEASE!!!! Someone help me PLEASE!!!
If you extract the audio using Virtualdub and save as WAV tyhen use as audio source in TMPGEnc ...you should be fine
"Today is only yesterdays tomorrow" -
Need more information. What's the framerate of your source, what's the audio source (many DivX files contain mp3 or even ac3 audio), what template/settings did you use in TMPGenc/Ulead, etc. etc.
yea, try extracting the audio and decompressing it to 41,000 khz PCM. also make sure your frame rate is right, find out what the frame rate of your video is, then make sure your settings for frame rate are ok.
And scan and remove any bad frames with Vdub first!
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
DVD to AVI (XviD / DivX) using VirtualDubMod Conversion problems.....
By dabas in forum Video ConversionReplies: 1Last Post: 26th Feb 2010, 09:12 -
Problems playing Divx / Xvid files on Silvercrest KH 6508
By Onihoshi in forum DVD & Blu-ray PlayersReplies: 7Last Post: 11th Oct 2008, 16:18 -
best avi (divx/xvid) to cd-r (vcd) converter
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 8Last Post: 15th Sep 2008, 13:36 -
Audio Problems with divx,xvid etc on dvd player
By iain123 in forum AudioReplies: 6Last Post: 30th Jun 2007, 15:57
