Help!
I have Asus TV tuner and all major decent soft works
exept VirtualDub. I cannot set custom format 720x480/RGB or YUY2
Error 118 pops out - unsupported format. I have WDM driver so I dont
understand why VDub doesnt work in 720x480. Actually it gives the same
error in higher then 320x... capture resolution.
Please help. I'd like to use some filters and VDub would do this at one time
instead of reconverting huge files for hours.
Big thanks.
Results 1 to 1 of 1
Virtualdub 32bits error: cannot connect to the desired capture driver!
By Cauptain in forum Capturing and VCRReplies: 3Last Post: 21st May 2011, 12:17 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 19:10 -
Why DVD (720x480) bigger than AVI(720x480)
By psxiso in forum Video ConversionReplies: 6Last Post: 3rd Feb 2008, 06:50 -
Anyway to capture 720x480 using the Gamebridge and still play?
By Mysteriouskk in forum Capturing and VCRReplies: 0Last Post: 19th May 2007, 14:07
