Hi.
Is there any way to join AC3 files. I have 2 MPEG (.m2v) files with the audio (.ac3) seperate and I want to join the 2 video and audio files into 1 system stream file (.mpg).
Tmpgenc allows me to mux the audio into the videos as 2 seperate files but when I join together the 2 .mpg files the audio is lost.
I can join the 2 m2v files together but is there any tool to allow me to join the 2 ac3 files together before muxing the single audio file into the single m2v file.
I would convert both to .WAV files, join, then re-convert back to .AC3. I don't know of a program that can join the .AC3s directly (but I believe that it would be possible to write one).
Thanks for the reply SLK001.
Can I join the wav files (how?) or do I need to multiplex with the video, join the 2 .mpg's and then demultiplex the audio out again before converting to ac3. -
Apparently you can join AC3s together using a simple DOS command :
copy /b part1.ac3+part3.ac3 both.ac3
(/b = binary file) -
Most of the time, .AC3 files have time indexes embedded in the headers. Programs that don't use the time indexes to sync to video could use the above method (if it works, and I have my doubts - but I haven't tried it). Those that do sync, would have a crisis with the different time stamps.Originally Posted by andymo
You'd need something like Protools or AcidPro 4.0 to join .ac3 files.Originally Posted by SLK001
You may want to take a look at this MP3 splitter and joiner. It is a very easy to use program. The cost is $19.95.
http://www.ezsoftmagic.com/
Join AC3 files
By rgraiche in forum AudioReplies: 8Last Post: 20th Aug 2011, 16:56 -
Split, join, create silence of an ac3 file
By phate89 in forum AudioReplies: 6Last Post: 16th Jul 2011, 14:34 -
How Do I Join M2V and AC3 Files?
By lovelylisa in forum Video ConversionReplies: 1Last Post: 6th Jun 2011, 18:13 -
How to join ac3 files?
By X_Splinter in forum AudioReplies: 9Last Post: 30th May 2010, 10:10 -
Join .MP4 with .AC3 to .MKV without loss of sync
By vanleeuwen in forum Video ConversionReplies: 2Last Post: 18th Dec 2008, 03:53
