I experimented by copying a vcd movie (.dat file) on my hard drive and then used nero to burn it in vcd format again. Nero did encoded it again..
Didn't do anything else.
I noticed drop in picture quality, audio to me was Ok!!
Any suggestion to keep the video of same quality as original.
Well unless its a lossless compression then your going to get lowered image qualitity. MPEG2 is lossy and therefor everytime you re-encode u lost quality. To begin with, Nero doesnt have a good encoder.
Look in the guides section for a tutorial on how to create a VCD from a DAT file... -
Why are you doing this??? If you've already got the VCD authored and burnt and want to make another copy of it just copy it like you would any CD/CDR.
There's no need to copy the dat file and re-encode/re-author the VCD. Also even thou the DAT file is playable by WMP as a MPEG1 file it really isn't. You should use a program (eg. VCDEasy, VCDGear, etc) to convert the DAT file back to a MPEG1 file prior to playing with it. -
so what will be the best way or program to burn dat back to cd without loose quality.
i know i can copy, but i want to do this, ( cos i may sneek my own video file with main movie
soooo plzzzz help
maximizing picture quality
By thekenoshakid in forum Newbie / General discussionsReplies: 24Last Post: 21st Sep 2022, 21:38 -
Poor Picture quality - need help!
By Martin747 in forum EditingReplies: 2Last Post: 26th Dec 2010, 12:00 -
How to improve picture quality
By MI6 in forum Video ConversionReplies: 2Last Post: 25th Feb 2009, 16:37 -
Youtube picture quality
By Juc1 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jan 2009, 20:36 -
picture quality
By nexous in forum RestorationReplies: 4Last Post: 18th May 2007, 04:03
