Greetings ,
I created MPEG-1 Non Standard format using TMPGEnc.
(Reason I used Non Standard is to reduce the file size so that I Can fit about 90 minutes on a 80 Min CDR. I used 128K for audio and 1000K for video. So the quality is slightly compromised by I can fit that in a single CDR rather than having that extra 10 mins in another disk)
Now that I got this MPEG-1 file, I am using the latest version of VCDEasy 1.1.5 to create the VCD. The software does not let me put any chapter access points.
Is their a way add chapter access points using VCD Easy?
(Other than creating seperate tracks, I know that is an option, but that means I need to cut my MPEG file! manual effort. VCDEasy can add automatically every 10 minutes etc.. Worst case I will do that.. but was wondering if thier is some setting etc..)
thanks in advance...
Nuf
looking for entry level title/chapter/angle info
By anilty in forum ffmpegX general discussionReplies: 4Last Post: 27th Mar 2009, 11:57 -
Number of possible chapter entry points: 1 - WTF?
By DRP in forum VCDEasy GeneralReplies: 20Last Post: 20th Mar 2008, 19:50 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 11:39 -
new chapter points in PGCedit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2007, 14:51 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 21:33
