Hello every1
I have a system i am going to install my canopus advc 50 in.
(Windows XP 256SDRAM 850MHZ celeron).
I have to buy a new HDD for DV capture and since the Firewire once are not so verry much more expensive i am wondering wich 1 would be best.
I have always used IDE hdd's.
SCSI is no use i have read somewhere (same as IDE almost), but then there are firewire..
Is Firewire HDD's External only?
Will they preform better than a IDE hdd in my system?
The new hdd is going to be a capture disc only (slave).
Will the firewire hdd eat up all the bandwith on the 1394 card?
Wich then again could destroy my capture.
Thanks for replies in advance! 8)
i think firewire are external only...
me personally i would just use an ideyou better BELIEVE
Disturbed -
The following 2 articles will answer most of your questions, especially since they include a test of the same Western Digital drive in IDE and in Firewire interface formats.
http://www6.tomshardware.com/storage/20030411/index.html
http://www6.tomshardware.com/storage/20030402/index.html
Bottom line, IDE is faster than firewire. On the other hand, an external firewire drive is portable.
I am not aware of any internal firewire HDD, especially since an external drive is just an IDE drive in a firewire enclosure (an interface converts the firewire external interface of the external drive to an internal IDE connection).
As for the external HDD eating up the bandwidth, I can't speak from experience, but I don't think so. The external drives in the article reach over 30MB/s while a DV capture is about 3.5MB/s. There is plenty of room there for both the stream coming from your DV device and to your external HDD.
sata HDD and IDE hdd
By rubberman in forum ComputerReplies: 22Last Post: 9th Mar 2011, 22:02 -
SATA HDD with IDE motherboard :-S
By Gyongyi in forum ComputerReplies: 29Last Post: 17th Oct 2009, 08:54 -
Enclosures with FireWire IDE or SATA?
By Sakuya in forum ComputerReplies: 15Last Post: 20th Jan 2009, 19:44 -
HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???
By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 13:38 -
FIREwire HDD, NOT in my computer,update NEW acomdata HDD works great
By theewizard in forum ComputerReplies: 22Last Post: 20th Jul 2007, 02:01
