I have tried a number of different methods of converting some Xvid movies to DVD ...
I've utilized the various templates for TMPGenc all of which have resulted in crap.
The best results I've been able to obtain thus far are with NeoDVD ... this conversion results in video with the following specs: Bitrate 8234 Kbps, 29.970 fps, res. 720x480 (16:9), MPG2 = MPEG 2 (SVCD/DVD). Based on everything I've read, this file should look pretty good, but when I play the DVD on my 36" television, it's all blocky and not very sharp at all.
The orginal Xvid files are 14.95(?) fps, res. 352x240 (16:9).
I guess my question is, based on the origin file, can I ever expect to get a GOOD quality DVD as a result, or am I wasting my time?
"Your head will collapse if there's nothing in it" - Black Francis
The problem is the original framerate and width/height.
Sizing 352x240 (VCD) up to 720x480 (DVD) will never look good.
In this case, you'll actually get better results by encoding the original
to a high bitrate VCD.
I recently transferred a 3 hour Xvid (25 fps, 640x480) file to DVD.
Because of the length I could really only get a bitrate of around 3000-3500.
I used TMPGenc's DVD standard template.
It came out very nicely when watched on my 32" TV.What's "taters", precious?
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41 -
Best possible quality XviD to DVD
By Mdoodm1000 in forum Authoring (DVD)Replies: 7Last Post: 9th Dec 2010, 10:01 -
Good Multi Region XVID DVD Portable player with IN's n Out's?
By iC3MAN in forum Portable VideoReplies: 0Last Post: 28th Dec 2009, 15:57 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 04:18 -
Can anyone recommend at good program for converting DVD to Divx or Xvid?
By gbgunner in forum DVD RippingReplies: 13Last Post: 10th Nov 2007, 18:18
