I have a problem. I have been trying to separate two episodes from one disk, each having four camera angles, and four audio channels. I have tried using vStrip to, and successfully, ripped it to my harddrive with the four angles, but am unsure about the audio. Also, the first episode has one chapter that needs to be removed, which was done successfully, but to my knowledge vStrip does not create new .ifo files and .bup, and need them to burn. I would also like to keep all of my chapter information. There is no clear separation of the files for each episode, i.e. episode one for files 1-4, sencond 5-8. The first episode bleeds into file 5 for one of its eight chapters. Any help would be appreciated as ive spent an extremely long time trying to figure it out
I have made several backups, and iI have found DVD2ONE to be the best... I don't know about all of you, but it seems like the encoding done by DVD Shrink is inferior.
Also, what do you think is the highest acceptable limit on a file to encode it to one disk? i.e. I believe The Matrix was 6 gigs, and I used DVD2ONE to compress to movie only and didnt see ANY difference.
One last question for you all.. I would like to put an extremely simple menu in. Just a still photo with one button: Play. Any ideas would also be appreciated.
Thanks a lot,
MadMax
JELLO YAY
it would be infinetely helpful if you actually told people what series you were trying to convert - you'll probly find that others have had the same issues and overcome them, or you might inspire others who also have it on dvd to try it out. But im getting the sneeky suspicion ur trying to convert porn, cause i know no series that would make good use of multiple angles 8)
I'm actually trying to make a backup of the 2002 Drumcorps International DVD's which utilize 4 camera angles and 4 auido tracks. Disks 1-3 have 2 corps on them because each angle is approx 650-770 megs apiece and disk 4 contains 4 corps with 2 camera angles and 2 auido tracks. Definately not porn.
JELLO YAY
As many episodes as possible on one DVD5
By nharikrishna in forum Authoring (DVD)Replies: 5Last Post: 25th Oct 2011, 07:56 -
vob to avi (tv episodes)
By stewart2000 in forum DVD RippingReplies: 13Last Post: 27th Sep 2008, 05:05 -
6 episodes divx -> 1dvd
By TWDuke in forum Newbie / General discussionsReplies: 7Last Post: 8th Sep 2008, 17:54 -
Split into episodes
By mparter in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2008, 15:09 -
Extracting Episodes from a DVD9
By Firewire60 in forum Video ConversionReplies: 0Last Post: 20th Feb 2008, 17:44
