I have Ulead DVD MovieFactory 2 and I have used that to encode but I just read it is not that good for quality. What, in your opinion is the best encoder?
This has been discussed in great depth in the past, do a forum search and you will find more than enough information.
Originally Posted by hardcoreruss
Just my two cents... -
OK well just some specs. I have:
Pen 4 2.53 ghz
1.5 gig ram
Geforce 4 ti 4200 128 meg ram
I don't really care about the speed that much, i can start encoding it before I go to bed or work Just interested in the best quality. -
main concept , tmpgenc and Cinema Craft Encoder are all good encoders ..
more depends on the quality of your source material and settings ... and what type of source files you have..
this subject has been beat to death many times .... and nothing really has changed in the last 3 years except main concept really burst on the scene .. -
it's also going to depend on you.
which interface are you more comfortable with? how much encode time is too much? do you want to get into the hardcore dirty-dirty with matrices, IBP codes, etc. or do you just want to plug your files in and hit start?
best answer is to download as many trial versions and give them a whirl, preferably on the same piece of test footage.
I like TMPGenc, because with the amount of work I put into it, I get results I like. I wish it was faster, but no big deal, I do major encodes overnight.
I didn't care for the results I got from MainConcept or from CCE, but that's me. Your mileage may vary.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
mpeg encoder for DSP
By mourya in forum ProgrammingReplies: 2Last Post: 31st Oct 2008, 11:28 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 15:56 -
DV to MPEG2 using Mpeg encoder
By neftv in forum Video ConversionReplies: 8Last Post: 16th Jul 2007, 06:39 -
The best DV AVI to MPEG-2 Encoder for me to use.
By leegutcher in forum Newbie / General discussionsReplies: 6Last Post: 7th Jul 2007, 07:54
