My source avi (divx encoded) doesn't "look" interlaced, but when I load it in TMPGEnc (using the wizard), TMPGEnc wastes lots of time "judging field order" and then tells me it is interlaced.
Now, in cases like this, when the two fields for each frame are clearly representing the same instance in time (i.e., not separated in time as in an interlaced source), but for some insane reason are being stored as fields in the source (I guess?), should I choose "progressive" as the encode mode? Does it matter? Will it make any difference in playback quality or encoding time? Does it matter at all whether the source is field-based or frame-based, as long as the source frames "look" progressive?
Results 1 to 1 of 1
Windows 7 Stuck in "read only" mode for USB THumbs and SD Cards etc..
By nerys in forum ComputerReplies: 26Last Post: 1st Mar 2012, 02:03 -
35 "VR Mode DVDs" made years ago-- need to finalize/make viewable
By Swarup in forum Newbie / General discussionsReplies: 10Last Post: 8th Nov 2011, 14:38 -
xvid-AVIs won't play until re-saved in "copy"-mode
By Information in forum Video ConversionReplies: 0Last Post: 5th Dec 2009, 09:03 -
Do hdtv owners use the "fill" mode to get rid of "underscan&
By yoda313 in forum PollsReplies: 20Last Post: 11th Jul 2008, 19:02 -
Decrypter "Brute Force" mode can damage the writer, or produce ba
By Bruxo in forum DVD & Blu-ray WritersReplies: 5Last Post: 2nd Dec 2007, 15:26
