hi i just sucessfully converted the first half of an avi to svcd....audio sync is perfect on disc1.....now i wanted to do the second half and...i keep getting an error because the audio is out of sync....i know this because the frame im starting from is 70127 but the sound begins from before that point...but i ripped the wav with virtual dub 1.54 and had no problems with the first half.....heres the error i get ........"Index of scan line is out of range (320)" .........i get this error when i begin to convert the avi and wave to mpeg with TMPGEnc ..........how can i fix this?
thanks in advance to all!
progs im using
TMPGEnc
Virtual Dub 1.54
Nero (later)
Why don't you convert the entire film to mpeg and THEN split it into two using tmpgenc's merge and cut under tools.
ive already tried that but for some reason the Xvid rips convert without any audio at all. now i have ripped the entire wav and still no luck any other suggestions?
It sounds like the AVI was split improperly. They should always be split on a keyframe.
The two may be unrelated. It sounds like the AVI is showing up with the wrong frame size. You could always frameserve it to TMPGenc to get around the error (check the GUIDES section).i keep getting an error because the audio is out of sync....i know this because the frame im starting from is 70127 but the sound begins from before that point
I would suggest you set your range (starting on frame # 70127) in VirtualDub, and then frameserve that to TMPGenc.Impossible to see the future is. The Dark Side clouds everything... -
Hey I've had the same problem. You're going to have to load the movie into virtual dub, use full processing on audio...44100 16 bit sound stereo etc. save to wav... then multiplex with virtual dub, then tmpgenc will recognize the audio part of the vid too. then you can split the mpeg into 2 parts using cut an edit with tmpgenc
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
