everything goes fine up until besweet starts reencoding the audio to 48k - and it freezes dead solid at 6 minutes in. i dunno if toolame isn't implemented yet (as to why it's greyed out) but i can't use it and i've no idea what to do now.
any help?
Guest
Have you tried using *exactly* the settings on BeSweet as posted here (on the left in the Convert guide area)?
"Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
Guest
i'm talking more or less whatever SVCD2DVD uses as the normal settings is freezing it up.
So that program calls BeSweet? Is there anyway you can convert your audio in advance? Even if you can't feed the results into that VCD program, at least by converting your audio yourself you can try and determine where the error is (because that VCD program is probably calling BeSweet with command line parameters).
In this version of svcd2dvdmpg, besweet is invoked as follows:
as mkelley says:Code:besweet.exe -core( -input "infile.mp2" -output "outfile.mp2" ) -ssrc( --rate 48000 ) -2lame( -m s -b 224 -e )
at least by converting your audio yourself you can try and determine where the error isSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Guest
okay, so i have the separate ac3 (had to do it manually from the mpg, no problem there), and an mpv file, but what's a good program to put them onto a DVD? the old spruceup doesn't accept the mpv file..?
mpv should be accepted by spruceup if you patched to 352
BeSweet for 4.0/quad AC3?
By RogerTango in forum Video ConversionReplies: 1Last Post: 17th Nov 2011, 04:16 -
BeSweet not converting to Stereo
By takearushfan in forum AudioReplies: 9Last Post: 1st Jan 2010, 12:10 -
besweet, belight
By volam in forum AudioReplies: 0Last Post: 9th Sep 2009, 21:53 -
besweet 5.1 wav
By dvdfreak1971 in forum AudioReplies: 1Last Post: 11th Apr 2008, 15:44
