Been using VCD Easy for about 6 months now on my Win XP system (Athlon 1000, 384mb, 120gb hard drive). I grab through my Hauppage card using VirtualDub, then convert using TMPGEnc. I then use VCDEasy to put Chapters in before burning to VCD.
Last night, I tried to do this with an mpeg I created exactly the same way as I've described above. The mpeg checkwent fine, but when I came to start the Chapter process, when I hit the button to mark in the first chapter point (i.e. at 0.00) I got a 'Floating Point' error message on screen, and I cannot set any chapters.
Anyone got any ideas??
Many thanks
Just a follow up to my message below.
I tried again when I got home tonight, still the same problem.
Thinking it may be a fault from the avi-mpeg conversion, I tried on an old mpeg that I've already put chapters on, and that was the same.
I uninstalled VCD Easy and then re-installed it-same problem.
I uninstalled VCD easy again and tried a previous version-same problem.
It's not like I've added any other software or changed any ocnfiguration. Yesterday morning it would let me create chapters, now, as soon as I hit the button to set the opening point for the first chapter, i get this Floating point division by zero error.
Anyone got any thoughts at all??
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 09:28 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 08:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 02:22 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
