I have 2 versions of a movie here, one original and one german dubbed. I encoded the german version just fine on one XVCD using more or less the VCD PAL presets (Adjusted the bitrate to fit on 99m mode 1 CD). Then I tried the same with the original with the same settings. When trying to mux the files the app quits. Looking at the video and audio I see that the video is 863 MB big and the Audio about 150 MB. That's too big. The whole file was supposed to be just 870. And with the grman version movie it worked. I tried to mux them manually. It worked but the file is too big and the sound totally asynchronous (sp?). Can it be that I have to use the VCD NTSC setting? Or what else could be the problem?
Results 1 to 11 of 11
PTTPGuest
PTTPGuest
The source movie is 29.97 fps. So I tried to use the NTSC VCD setting.
But I get this error:
**ERROR: [mpeg2enc] Input stream with unknown frame-rate and no frame-rate specified with -a!
The video encoding doesn't happen and it starts the sound encoding.
Note that all I changed was from PAL VCD (which worked basically but produced a file too big and out of synch sound) to NTSC VCD. As for the bitrate settings: I use the bitrate calculator.
PTTPGuest
Grrr...
Now with 0.0.7a I get this:
Encoding started on Mon Jun 9 14:32:58 CEST 2003
Input #0, avi, from '/Volumes/xxx/xxx/xxx/xxx/xxx.avi':
Stream #0.0: Video: msmpeg4, 512x416, 29.97 fps, 800 kb/s
Stream #0.1: Audio: mp3, 48000 Hz, stereo, 112 kb/s
Output #0, yuv4mpegpipe, to 'pipe:':
Stream #0.0: Video: rawvideo, yuv420p, 352x240, 29.97 fps, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
**ERROR: [mpeg2enc] pel_aspect_ratio must be between 1 and 14 (MPEG-1)
Is there a 0.0.7b?
PTTPGuest
What program do I use to make a small clip from that kind of AVI? (See description in error meg. above)QuikTime won't handle it well...
Interestingly I get the same error when trying to use the VCD (NTSC) preset to recode a MPG1 muxed video to VCD (yes it's already in VCD format, but I can't burn it to CD for some reason, probably because it was joined from 50 pieces).
Anyway, get the same error with 0.0.7a, but it works flawlessly with 0.0.6g (which luckily I kept when I upgraded yesterday):
Encoding started on Mon Jun 9 17:19:18 CEST 2003
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
Input #0, mpeg, from '/Volumes/data4/rips/NoOneToLove_2.mpg':
Stream #0.0: Video: mpegvideo, 320x240, 29.97 fps, 1500 kb/s
Stream #0.1: Audio: mp2, 44100 Hz, stereo, 192 kb/s
Stream mapping:
Stream #0.0 -> #0.0
**ERROR: [mpeg2enc] pel_aspect_ratio must be between 1 and 14 (MPEG-1)Peter van Aarle
my xvid videos are too big in filesize
By C-Royd in forum Video ConversionReplies: 1Last Post: 6th Aug 2011, 17:31 -
Movie to big for screen??
By bunkerhill in forum Newbie / General discussionsReplies: 6Last Post: 4th Jan 2010, 06:09 -
Big blocks on XVid to MPEG conversion
By hewsongs in forum Video ConversionReplies: 7Last Post: 30th Mar 2008, 16:50 -
cannot seek in big (>2 GB) XVID files
By adwiel in forum Video ConversionReplies: 1Last Post: 25th Jan 2008, 01:41 -
Movie seems to big
By DarkLogan in forum Newbie / General discussionsReplies: 5Last Post: 17th Aug 2007, 16:18
ec first).
