  1. I have been working alot with Scenarist 2.6 recently, but I cannot figure out how to create a menu that allows me to set the Audio stream for a Video.
    Basically I have a DTS track, a commentary track, and a 2 channel Dolby Digital track, and I want to create a menu that that will set the audio stream that will play when I start the Video.
    Any Help would be great!
  2. Member adam's Avatar
    Sep 2000
    Create the menu for the audio selection, and create that button. Go to the button commands tab in the simulation window. If its not showing up than first add your item to the Scenario Editor and from there double click on the little tag labeled "Btns."
    For each button used to select a language, set its command to "Set Angle/Audio/Sub-Picture" and fill out whatever options you want it to use when you select this button. So for your case, you'd just want to change the audio to the appropriate stream. Now if you just leave it at that, then after making your selection you will remain on that menu. Some people prefer to have it jump back to the main menu after changing the audio track. If you want to do this, then look to the bottom right and you will see a link option. Check this and now you can set where you want to jump to, ie: Jump to PGC, Jump to Program, etc...
  3. Thank you very much, that was very easy!
