well this issues i have when i try to create DVD (mpeg2) files, for some reason it won't let me create one file, instead it creates two files one for video (m2v) and one for audio (wav).
there is an option there that supposed to let me turn that off, but its grayed out, so i can't.
is there any work around?
i remember i had an previous version that didn't do this, but i don't have the installer anymore.
Hello
That is because you picked LPCM sound. If you want to create a mpeg file with TMPGEnc then you have to use MP2 sound (also called MPEG-1 Layer II Audio).
When you select MP2 sound then you will have the option to either output a mpeg file (filename.mpg) or elementry streams (filename.m2v and filename.mp2)
thank you so much
i hate when they do such big changes in new versions -
Hello
I should point out that you can mux (multiplex) AC-3 audio and a M2V file together get a single mpeg file but of course TMPGEnc does not do AC-3 encoding.
White Screen in TMPEGEnc 4.0
By barrylay in forum Video Streaming DownloadingReplies: 0Last Post: 1st May 2011, 15:09 -
TMPEGenc h.264 conversion error
By iGnight in forum Software PlayingReplies: 2Last Post: 16th Jan 2011, 10:14 -
Remove subtitles from MKV when converting with TMPEGEnc
By ikarishinji41 in forum Video ConversionReplies: 3Last Post: 10th Dec 2009, 10:21 -
TMPEGEnc DVD Author Ordinal Error
By justin81 in forum Authoring (DVD)Replies: 2Last Post: 17th Aug 2009, 20:33 -
TMPEGENC keeps closing itself because of an error
By Akhet in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2007, 00:38
