So I have two .VOB files which I'd like to join, cut a little off the ends, and plop into an MPEG 2 file on my hard drive. Im aware I could do something like this with DVDx ripping it directly off the DVD, but I dont want to re-encode this video (it already has been twice).
Now, using the MPEG Tools, Merge & Cut feature of TMPGEnc, I load them both up. The first VOB works fine, but the second, I get an error message saying its not an MPEG.
Both VOB files work fine in VirtualDubMod, so I though maybe I could frameserve them into Merge & Cut, however, both now get and error of not being an MPEG. The frameserving works fine if I open the files into the "Video Source" of TMPGEnc.
My question: Is it possible to do this, and if so how do I fix the error... or Is there a better way to do this without purchasing software and such.
Thankyou for any help.
Guess I solved my own problem, here how:
I used VobEdit to join the two Vob into one, which then did work in TMPGEnc. I had to do the sound separatley and then multiplex it in. It was about .2 seconds off so I had to sync it by trial and error, but the end result looks good.
How to add our products in your "Tools"?
By lengdatou in forum FeedbackReplies: 4Last Post: 28th Sep 2011, 04:32 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
What are the top "photo and video to dvd" creation tools?
By extent in forum Newbie / General discussionsReplies: 69Last Post: 8th Sep 2010, 17:04 -
Tools suggestion: adding "see also:" to the searched tool ?
By vhelp in forum FeedbackReplies: 0Last Post: 22nd Feb 2009, 11:03 -
Do they still have "invisible" surfing tools?
By yoda313 in forum ComputerReplies: 3Last Post: 15th Oct 2008, 12:24
