How long does it take to encode a 60min movie with Tmepgnc?
it all depends on the persons set up. on my machine i can do it in real time if not faster.
[ = Check out my band @ www.samadhirock.com = ] -
what you mean by persons setup? and how long does it take you to encode a 60min video?
Hey Beautiful lonley have you seen his computer detail P4 3.06 Ghz 2500 mb of ram i mean the guys is definetly rich so he has a supped up pc one that i wish i would like to have similar. plus the speed in tmpeg depends on what size reselution your using like if i make a vcd at motion estimate search fast since its a low reselution it does it in real time and you still get ok quality ok because its VCD not because of the motion estimate search shit. and if you do dvd reselution that takes way longer well at least on my CPU i dont know about that other dude.
An all in one guide for DVD to CVD/SVCD/DVD by cecilio click here--> https://www.videohelp.com/forum/userguides/167502.php -
Originally Posted by Beautiful Alone
Change to highest motion search precision and you can double those times, adding filters could treble the encode time, or even more.
So the answer for me would be between 55min and about 20 hours. So like i-on-s said, it depends. -
ReddGeronimo -
Depends on what you're doing. I've seen realtime, faster than, and slower than. It is faster than most other systems available, with the exception being some RISC systems like SGI and maybe some dual-G4 Macs. Couple others, but for standard home/office setups, it's darn fast.
I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
cpu vs gpu for video rendering with i5 460m 2.53 ghz
By Edgarke16 in forum Software PlayingReplies: 6Last Post: 3rd Jan 2012, 05:43 -
Cores Vs. Ghz for photo programs ?
By Noahtuck in forum ComputerReplies: 31Last Post: 9th Sep 2010, 22:06 -
computer power ghz ?
By luc13137 in forum EditingReplies: 6Last Post: 2nd Aug 2010, 22:08 -
P4 3.06 ghz
By Haopengyou in forum Newbie / General discussionsReplies: 2Last Post: 23rd Oct 2009, 14:26 -
CPU-Z reading for Intel Allendale cpu
By budz in forum ComputerReplies: 11Last Post: 8th Jul 2007, 19:33
