Ripped DVD with Clad...tried to use DVDx1.4 to encode but couldn't find an IFO file in the file that I directed to in Clad. I even tried selecting the IFO file from the DVD drive...that obviously didn't work. Any Help?
Did you try to copy the .ifo file from the dvd to your HD. If you have a listing like this:
vts_2_0.ifo
vts_2_0.vob
vts_2_1.vob
vts_2_2.vob
vts_2_3.vob
etc.
just copy the largest .ifo in the listing sequence that you want. These files are unencrypted.
or you select them with clad and they will be copied for
you. just make sure you select the CORRECT .ifo
