What if I were to download a movie from Kazaa that played just fine and nothing seemed wrong with it until I went to move it to a new folder. I was then told it was being used by another person or program which was not the case. So what I did was copy it to the folder I wanted to and then deleted the original. Could this have been a corrupt file? If so, should I get the movies off my hard drive and onto a disk so it won't harm my computer or is this really not a big deal?
I appreciate anyone's opinions.
Not a big deal.
If you had of reset your computer and then tried to move the file there shouldn't have been a problem as the program that was using the file shouldn't be anymore.
If the problem still existed then just go into DOS and move the file there. -
Ok, thanks for the info. I probably won't worry about it then since my computer is running top-notch!
are you using xp? if so, that is a major problem with xp. it took me a while before i found out how to fix it.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
uh. how do you do that? some kinda registry thing right?
or are you going about it by doing an end-task on explorer and then moving it through the task manager thing -
Yeah I am running XP, but I went ahead and just moved the movie files to discs that way they are off my hard drive.
Corrupt MTS files
By Curtis789 in forum Video ConversionReplies: 6Last Post: 21st Feb 2013, 14:37 -
MP4 Corrupt files help please
By TomoachiChan in forum Newbie / General discussionsReplies: 2Last Post: 18th Oct 2010, 12:06 -
Corrupt AVCHD files?
By Outback Paul in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 26th Jun 2010, 17:31 -
By Outback Paul in forum Software PlayingReplies: 2Last Post: 21st Jun 2010, 22:42 -
Corrupt VOB files..?
By djdust in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2008, 19:16
