I tried to back up my legally owned (by me) X-Files Season One, disc 1 using DVDShrink ver 2.0...however the copied DVD-R will not play. I get a message "This disc is not formated to play in this region".
I tried twice, using compression level 6 and as region free and as region #1...
Any ideas ?
Results 1 to 9 of 9
set DVDShrink for Region free insted of choosing a Region. it should work.. if not, try ripping with DVDDecrypter before using dvdshrink
and btw.. Level 6 would look total shit... you can't put 4 hours on a single DVDr ! -
This is off-topic but where can I find DVDShrink 2? I can't seem to find it on this or any other website.
dvdshrink version 2:
http://www.dvdr-digest.com/software/software.php?file=dvdshrink -
But you were advised to use DVDDecrypter, not Smartripper.
Decrypter seems to be able to perform miracles nothing else can -- my hunch is this is an RCE protected disk, which DVDShrink can't handle (yet -- the author hasn't been able to find an RCE protected disk to be able to fix this. I guess in some places they are as rare as hen's teeth). Decrypter is supposed to handle these just fine.
My hunch is that if you first rip with Decrypter and then use DVDShrink (on the files on your hard drive that Decrypter creates) it will be just fine."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
I don't use DVDShrink, but i assume that after the transcoding process it generates a VIDEO_TS folder for you to burn? If so then run IFOEdit, open the VIDEO_TS.IFO file and make it region free.
Does DVDShrink make the disc all regions or region 0. Because a few standalones actually have problems playing region 0 discs. -
I used DVDDecryptor to create an ISO image;
Mount with Dameon tools
DVD2One to shrink to 1 DVD
Burned with Nero to Verbatim DVD+r 2.4x disc
Plays great in my APex 1500; pixelation only with high change action scenes but barely noticeable.
Never get region problems doing this.
Z
BD-R (Ver. 1.1 1L), BD-RE (Ver. 2.1 1L) discs
By mobie29 in forum Authoring (Blu-ray)Replies: 2Last Post: 13th Jun 2010, 14:57 -
problem with DVDShrink finding files
By chaskar in forum Newbie / General discussionsReplies: 8Last Post: 5th Jan 2010, 16:48 -
Video_TS Files (DVDShrink) to DVD
By ione in forum Newbie / General discussionsReplies: 7Last Post: 26th Jan 2009, 22:18 -
DVDShrink - Where are the dump files
By mn072065 in forum DVD RippingReplies: 15Last Post: 25th Feb 2008, 07:48 -
i have spiderman season 1-5 and its .avi. can i burn each season on dvd?
By dizzlenizzle87 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2007, 00:23
