I just authored my first DVD using Workshop. It is a bunch of children's cartoons for my daughter. Unfortunately, she can only move to certain menu items (there are a total of 12 on the main menu) and I can't seem to control their order! If we hit the right arrow on the remote, we might visit 3 cartoons on the menu, but the rest are not selectable.
I feel like there is something very fundamental I'm doing wrong.
Each cartoon is a separate Title with only 1 chapter.
Can anyone help? A details explanation of what to click on to fix this problem would be immensely appreciated.
Thanks very much,
Brian
If you're just starting out with Ulead DVD Workshop, then I would recommend that you use the menu wizard, if you haven't already.
I just did a test.
1. Opened DVD WORKSHOP;
2. Clicked NEW PROJECT icon;
3. Gave new project a name;
4. Clicked the LOAD VIDEO FILE icon and loaded 12 video clips.
5. Loaded all 12 videos into the TITLE LIST;
6. Clicked the SHOW/HIDE CHAPTER LIST icon;
7. Clicked the MENU step button;
8. Chose the MENU WIZARD option;
9. Clicked the ADD ALL button;
10. Clicked the NEXT button;
11. Clicked the FINISH button;
12. A remote keypad test screen appears and this is where you should check the functionality of your menus.
Should work if you follow these steps.
There are also some helpful tutorials located here:
http://www.ulead.com/learning/dws.htm
Hope this helps.
Jerry Jones
http://www.jonesgroup.net -
Jerry,
Thank you for the detailed directions! I will go through it.
I've noticed something odd... it works fine when I use the Wizard, but if I draw the menu from scratch, that's when the menu buttons behave strangely. Weird...
Thanks again.
-Brian
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 03:04 -
Ulead DVD Workshop 2 replacement?
By msimon7 in forum Authoring (DVD)Replies: 26Last Post: 2nd Sep 2010, 10:25 -
DVD Menu with Chapter and Menu Template.
By big-boo in forum Authoring (DVD)Replies: 3Last Post: 17th Mar 2008, 07:20 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 03:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 03:55
