  1. Hi,
    I'm new to this capture thing and have tried the AverTV and WinTV. My problem is that I can view and listen to TV without a problem and it sounds fine. BUT, when I save the file and then play it back It has a nasty high pitch hum/hiss, thing going on.
    How do I get ride of this?
    Thanks for all your help
  2. Any takers ??
    Does anyone know what is causing this and does all capture cards have this?
    Any and all help is appreciated.
    Feb 2001
    Hi,
    Maybe your volume settings are too high when you're capturing? Have you checked the levels inside the application, and within Windows Volume applet?
    /\/\ars /\/\ayhem
  4. yea... i checked the volume levels. I tried them high, then mid. I checked the app, and the windows settings.
    mmm... thanks for the thought.
    Does anyone else have this problem?
    Thanks,
    Dec 2002
    Texas USA
    Does your source have hiss? If so, use a noise removal program on the final capture. Some AUDIO RESTORATION techniques are in the guide in my signature.
    I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
    Apr 2002
    Tucson
    I too have noticed this with the avertv card.
    It's seems to only occur when you use the audio line in with the loop back to your sound card.
    I have no problems when I use the the coax input (ie a vcr) or if I input the audio directly to my soundcard (instead of the sound going into the avertv card then looping that to your original soundcard.
    Some other users have sync issues not using aver's line input but I haven't so it might not work with your setup.
  7. ooooo... thanks for the ideas. I'll give them a try and let you know what I find. The help is greatly appreciated.
    Thks :-)
  8. What's the update on this? I'm surprised more people don't get this problem...I've always had the audio hiss in TV captures...I can tell when a TV is on because I can hear the hiss. Does this mean not everyone hears it?
