i opened up my .avi in virtualdub, and i got an error message saying to decompress my entire audio stream, and re-compress it with a constant bitrate encoder.
can someone tell me where i can find a "constant bitrate encoder"?
thanks,
please be more specific... i dl vd mod and i don't know where 2 go from there.
is there any good wav compressor i can use besides droopy eyes software (Dwavcompressor)?
thanks, -
Are you still getting the error with the new Virtual Dub?
Hello. -
it isnt an error, i need to compress my audio correctly... i need a software that can do it.
To compress audio into WAVE or MP3, try Goldwave. To compress it into Ac3, try HeadAC3.
Hello. -
VirtualDub is just telling you that the VBR MP3 audio in your AVI is encoded incorrectly. To fix it, you set your AUDIO menu to "Full Processing Mode". From the FILE menu, select FILE | SAVE AS WAV. It will prompt you for a filename. Be aware these uncompressed WAV files can be over a gigabyte in size. Make sure you have enough space to save the file.
The WAV file that is created will need to be converted to a compatible format. If your creating a VCD/CVD/ or SVCD, you can simply convert it to MP2. If you are creating a DVD, I would suggest you use AC3.
Download BeSweet and BeSweet GUI from the TOOLS section to convert your WAV to any of these formats.Impossible to see the future is. The Dark Side clouds everything...
Variable Bitrate or Constant Bitrate?
By i am x in forum Video ConversionReplies: 3Last Post: 12th Feb 2010, 07:49 -
Both constant bitrate and two press bitrate are the same,right?
By tendra in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 04:35 -
I need a constant bitrate
By alexv305 in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2008, 06:38 -
how to set max bitrate(xvid virtual dub)
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th Feb 2008, 08:54 -
Variable and Constant bitrate ??
By VEBouto in forum Newbie / General discussionsReplies: 4Last Post: 17th Oct 2007, 23:56
