I see I have this adjustment on my 48 inch JVC and the settings are Low or High. Which setting should I select?
normally the colour settings make the picture COOL by making the pic a little Blue or WARM by turning up the Red
this is what my Sony has
is there not just a NORMAL setting? -
No normal setting which I thought was a bit weird. All it has is low or high and I think it defaults to low as that was what it was set at when I came across it.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
Panasonic AG-1980 "Color Banding"
By mugenmidget in forum RestorationReplies: 5Last Post: 2nd Jun 2010, 10:32 -
DVD-lab PRO v1.6 - "Map" only gives the color black
By Paker in forum Authoring (DVD)Replies: 1Last Post: 3rd Sep 2009, 14:30 -
"inverted" color screen on laptop. Help??
By Super Warrior in forum ComputerReplies: 5Last Post: 18th Mar 2008, 19:51
