I tried to cut an avi. movie into two with VirtualDub but the audio does not match the video. How do I fix this problem.
I have the same problem with some videos, not with all. I didn't find a solution. I still have these movies on the disk because of a few MB I am not able tu cut.
P.
I capture 1 hour of video everyday with vdub and then cut out the ads and save the 45 minutes left. I have only had audio sync problems once (unfortunately didn't catch it until I had already encoded to mpeg2). I never worry about cutting on key frames.
<font size=-1>[ This Message was edited by: lemmy999 on 2001-09-24 13:30:20 ]</font> -
It is after I cut it. When I put the audio to fulll processing and video to direct streamlaod then they are both in sync but then it becomes to big to put on a cd.
Well if the original DivX is over 400Mb then the result Mpeg will need to go on 2 VCD's. Spilt the DivX in half before converting.On 2001-09-25 09:53:28, Fallout99 wrote:
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 14:24 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 04:46 -
Virtual Dub Mod Saving Problem
By cdgfx84 in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 14:08 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 20:49 -
Ripping DVD & Virtual Dub Problem...
By Chana1 in forum DVD RippingReplies: 7Last Post: 8th Jun 2007, 08:45
