Ok, I had no problems with AVISynth 2.52 and TMPGEnc 2.511. Then I upgrade to TMPEG 2.512 and now magically it doesn't work anymore. NO OTHER CHANGES WERE MADE! It no longer reads the correct number of frames in any larger AVI file (it always cuts them off short), and it will screw up the timecode throughout the file. I have run the avisynth script through VirtualDub, MainConcept, and CCE without a single problem.. TMPGEnc is just messed up though.
On a similar subject, it will screw up in the same way reading a file frameserved by VirtualDub also. I don't know what to do. I have tried everything. Re-installed every program including previous versions (except for TMPGEnc which I can't find on their site). I have tried different versions of all the plugins. I guess I have no idea what's left to try. Please help.
Results 1 to 12 of 12
I can't be the only one having these problems... Anyone else getting TMPGEnc not showing the correct number of frames to be encoded?
I had problems with TMPGenc in the past by upgrading for no reason. That's why I'm still on 2.59. No reason to change. While I unfortunately cannot help you with your problem, try to not be an upgrade-junky in the future. As we say in Texas: "If it ain't broke, don't fix it." Good luck, and maybe consider a "downgrade." Although is it really a downgrade when you make it work better with an older version?
I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
@txpharoah: We, from mediterenean countries, also have a phrase for solving problems with PCs.
For any PC problem, you have only one solution. Format C:
The "If it ain't broke, don't fix it." is wise, but for some strange reason, nobody here seems to follow it.
I actually tried to "downgrade" with a copy I got off of Kazaa (2.59) and my serial. It was still the same problem. This leads me to believe 2.512 installed "something" that wasn't removed.
I am an upgrade junky, but I can't "recall" anything else that was changed between this time except for avisynth (to get out of beta), decomb (which I have switched back and forth with the old one) and TMPEGEnc. All combinations of all three have resulted in nothing so far. -
How can you folks actully have 2.59I had problems with TMPGenc in the past by upgrading for no reason. That's why I'm still on 2.59.
WHEN THE WBSITE SAYS CLEARLY on the top line
May/20/2003 Update: TMPGEnc Plus 2.512 is now available online
I can't even get 2.59
as it isn't released at their own site
So WHAT GIVES? -
you get it from a P2P file sharer. With a valid serial number you are entitled to use whatever version of the software you want to, especially if the most recent version screws everything up. I just wish I hadn't deleted my 2.511 installer.
You can get version 2.510, 2.511 and 2.512 from here:Originally Posted by dcsos
http://www.pegasys-inc.com/e_main.html
Hope this helpSome Day I will….. -
dcsos -
don't look at it as Two point Fifty-nine - look at it as two point five nine, followed by two point five ten, two point five eleven, etc.
not a good way to indicate new versions... they need another "point" in there...- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Couldn't agreed more.... Not the best version track for the users, but who knows, it may work for them (TMPGEnc).Originally Posted by housepig
GOT IT..! Thanks
like incremental bumps in NERO but without the DECIMAL -
I keep all versions of my software so I can install an older version if I need to. I never discard a version or installers of any program just because I upgrade. I keep the older versions CD or downloaded software on a HD and they have saved my a** on more than one occasion. Newer is not always better TMPGEnc is only one example. Check that all the files are in the proper directory and folder and the new version did not install in a different folder leaving necessary components in the old location?
Good luck
I know this does not help your situation now but it very well can in the future.
Dd(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio
XP Installations. Big problems.
By SE14man in forum Newbie / General discussionsReplies: 23Last Post: 9th Mar 2010, 09:43 -
WinDV sync problems (Update: never mind, it's a TMPEGEnc problem)
By timmus in forum Capturing and VCRReplies: 0Last Post: 6th May 2009, 14:39 -
FFDShow Big Colour Problems
By Endemoniada in forum Software PlayingReplies: 3Last Post: 28th Feb 2008, 22:19 -
big conversion problems
By insyder in forum Video ConversionReplies: 0Last Post: 7th Jan 2008, 10:02 -
BIG problems with subtitles!!!!
By patoja76 in forum Authoring (DVD)Replies: 1Last Post: 11th Aug 2007, 11:00
