Results 1 to 10 of 10
  1. Anyone having problems logging onto cdcovers.cc? I haven't been able to get on for 2 days now.
  2. I don't understand this. I've tried no less than 30 times in the past 3 days, and all I get is a DNS error page, saying something like "Unresolved Host Name". Is anyone else having this problem?
  3. The following is what I get EVERY time I try to log on:
    Problem Report
    The system detected an Unresolved Host Name while attempting to resolve the host specified in the requested URL.
    Message ID
    UNRESOLVED_HOSTNAME
    Problem Description
    DNS resolution failure encountered.
    Possible Problem Cause
    The host entered has a mistake, or the requested Web site is temporarily unavailable in DNS.
    Possible Solution
    Examine or correct any mistakes, or try again at a later time.
    This is the URL that I've used for several months
    http://www.cdcovers.cc/vcd_0.php
    I've even tried http://www.cdcovers.cc/, same thing.
  4. Both those links work fine, minus the comma on the second link.
  5. You haven't recently installed any new software by any chance?
    I had a problem awhile ago accessing certain sites due to some spyware that installed itself on my computer.
  6. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Actually I can't hit cdcovers.cc at all right now. But I know I could yesterday.
    http://www.internettrafficreport.com/namerica.htm has a few red areas here in the US, no clue if its related however.
  7. I can't get there from the US. I found a brazilian proxy and was able to use that to get to them (slow) but it worked. Must be some problem affecting the US like they had before awhile back.
  8. All of a sudden all is OK again. Must be a gremlin running around in my puter. I do have another site that I still can't get into though, and I'm assured by E-Mail that it's not on their end. I tried my ISP all morning with no luck. I'll have to try them again. At least I'm getting back into cdcovers.
    Thanks for the help guys.
