Hi.
I have downloaded a vcd-file and when I start it in my computer i works very good.
When I burn it to a cdr in Nero the sound is gone.
Nero gives me the options to either:
"turn of standard compliance and continue"
"Re-encode the video"
or
"Cancel"
I tried the first option...
I can see itīs a valid vcd in mv-type.
Any idea?
Any help is highly appreciated
Stefan Ljungstrom
Open the MPEG in TMPGenc (the DAT file from the disc can be opened as if it was a standard MPEG).
To do this, select FILE | MPEG TOOLS. Go to the DEMULTIPLEX tab, and browse to your DAT file. It should report Video an Audio stream information. Chances are, your audio stream is not VCD compliant. The audio should be "MPEG-1 Audio Layer-2 44100Hz 224kbps". The bitrate (kbps) may be different but the rest of the file specs should read the same.Impossible to see the future is. The Dark Side clouds everything...
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 11:11 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
No sound when converting muxed mpeg-1 file to AVI DivX!
By mute82 in forum ffmpegX general discussionReplies: 5Last Post: 25th Oct 2007, 12:56
