I've tried to author a DVD with DVDMaestro, but unfortunately it doens't support movie-files larger then 2GB. Now I'm searching for a tool to split my m2v-file in two pieces. I tried TMPGEnc's MPEG-Tools, but afterwards DVDMaestro couldn't import the file any more. Does anybody know a (freeware) tool to split my file in 2GB pieces ?
i've just authored a 2.33Gb .m2v file with DVD Maestro, and had no problems.
that's strange. if i try to drag the file from the assets-bin to a movie-item dvdmaestro says that this asset is to big. on other internet forums i read that it is because of the file size. i've got dvdmaestro 2.5sp1. is it possible that it supports larger files in a newer version ?
Just to check trivials: what OS and filesyste do you use?
I run Maestro on W2k and NTFS, and it accepts any fils, even above 4GB
regards
dumb -
i use it on windows server 2003 with ntfs and it doesn't accept files larger then 2gb. the error message is: "the video asset length is greater than the maximum allowed". so what do i do wrong ? is my version to old (v2.5 SP1) ? or do i have to enable any setting in the software ?
Good, so the OS and the filesystem are OK.
I am using v2.9.2915a - but have no idea about what difference it has comparing to v2.5. Still might be some settings in Maestro - I cannot check it now, as my machine is currently busy with encoding. If I find something, will get back to here
Regards
dumb
MPEG 1920x1088 DVB not splitting
By Adoll in forum DVB / IPTVReplies: 6Last Post: 28th Mar 2011, 17:43 -
Splitting Mpeg-2 DVD files..
By Veepa in forum EditingReplies: 2Last Post: 11th Mar 2010, 04:25 -
Splitting vob(mpeg)
By Peterrrrr in forum EditingReplies: 4Last Post: 17th Nov 2008, 12:24 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 08:18 -
splitting an mpeg-2?
By php111 in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 18:18
