I know the type of media is important for creating DVDs, but is the cheaper media i.e Bulkpaq ok for data storage
Roy
For data storage, the best format by far is DVD-RAM if your writer is compatible with it.
Philbiker -
Quick answer is NO.Originally Posted by Roy47
Look at the reasons why cheap media fails with DVDs - read errors (or, what is there isn't what should be there). If the CRC errors are too large to fix on a DVD-R, you get blockiness, freezes and stuttering - but no disk failure (unless things get really bad). For a DATA FILE, if the CRC errors cannot be fixed, then you get the READ FAILURE OF FILE XXXX.EXT IN SECTOR ##### and an abort.
So, if you love your data, then spend the extra to store it on a quality disk.
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 06:07 -
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 22:05 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 07:52 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 18:58
