    Jan 2003
    I'm looking into CinemaCraft Encoder for encoding my Avid Xpress DV files. I've been using TMPGEnc, but I want to try CCE. But is there any way for CCE to read quicktime reference files? That's how I encode with TMPGEnc. It saves a lot of time when exporting from the Avid. All it does is reference the original media, so the encoding is done directly from that.
    Thanks in advance,
    steelborn
  2. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Works just fine.
    Jan 2003
    What settings do you use for DVD encoding?
