I am using Womble Mpeg2Vcr to cut and join my mpeg2 files. There are 2 questions. One is, is there a limit at the size of the mpeg file that it can open? Is it 2000mb? I ask this because whenever I try to open an mpeg file over 2000mb, there is no response from the program.
The second thing is, the mpeg files it created are always 16:9, is there any way to change it?
It usually keeps what ever AR the input file is.
To change it, when you save a clip click on the video button, it says pel-aspect ratio. For 4x3 set it to 3/4, 16x9 is 9/16.
To change an MPEG you've already saved, just use Re-Stream, DVD Patcher, or any other MPEG header tool.
I've used MPEG-VCR with upto 22 gig mpeg2 files, perhaps your using an older version? Or that mpeg has a problem with the gop at that point. Try to run the MPEG GOP fixer, see if it fixes it. -
What is the latest version?
I am using 3.03, and I don't have the option to change aspect ratio.
May be it is all because of the problem of my old version. Where can I find the latest version? -
http://www.womble.com
The current version is MPEG-VCR V3.14 (04/2003), built on 05/21/2003, and first released in February 2003.
from the same site.
Womble Mpeg Editor help, please. Thanks.
By seymoria in forum EditingReplies: 9Last Post: 20th Sep 2013, 06:20 -
Womble 5 installation question
By netmask56 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2011, 20:07 -
Womble and HD
By ADigitalMan in forum EditingReplies: 24Last Post: 15th Jan 2010, 01:27 -
Womble Gone?
By cyberboy in forum EditingReplies: 13Last Post: 9th May 2009, 18:08 -
Womble or TMPGEnc MPEG Editor?
By Mike99 in forum EditingReplies: 14Last Post: 11th Aug 2008, 09:32
