  1. Anonymous
    Guest
    When i open ffmpegX an error apears saying "AppleScript Error -10"!
    I'm using OSX 10.2.6!
    Thanks.
  2. Have you first run the installer successfully? Have you copied both the installer and the application to your hard disk? Have you trashed all previous versions of ffmpegX (and emptied the trash)?
  3. Anonymous
    Guest
    Yes. But there is another problem. When I click on the ffmpegX installer a message appears saying "AppleSript Error 1078".
    I don't know what to say .
    Thanks anyway
  4. Try to install OSX 10.2.6 combo, there is any change?
