i am new at this, so i was wondering if this is possible..can a person convert VHS tapes onto VCD..I have concerts taped onto VHS and would like to put them onto VCD..Can it be done,if so how..please e-mail me as i don't get back here everyday..here is my email
bigwurock@yahoo.com
if you can give me any info that would be great!!
thanx,
-jeff
You can get the hardware and software to do it, or simply send the tapes to me
I have found the easiest, maybe not the cheapest, but the best way is to get a mini dv digital camera such as the sony trv17. I dub the vhs to the camera onto a digital tape. Now I have a good digital copy.
Then import the footage into premiere with firewire and youa re good to go. Forget all of those capture cards and inputting through the computer. A real pain. The cost is the limitinf factor here.
Well its posible but depends on how much hardware you might own and what you want to spend.. In order to accomplish sucha task, you need an svideo connection on your vcr and svideo in on your video card. and then do it like that. I imagine it wopnt be half as good quality though since u r going from analog to digital but give it a try.. I dont know though.. never done this.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 14:25 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 08:19
