I get an error message with my Fujitsu laptop when trying to play a video
"Create overlay failed. PLease lower your screen resolution or color depth and try again."
I've tried every combination of screen resolution but nothing seems to work.
On Interactual Player I get "Playback failed due toa problem with the video subsystem"
HELP!!!
carpe diem mañana
Yes, I've got the same problem in my notebook and my new PC.
I've asked InterVideo support, no answer yet.
Maybe the video chipset isn't supported by the sw.
The same message with WinDVD Creator,but then it works anyway.
Any guru up there? -
I've solved the problem in my NB.
See :
https://www.videohelp.com/forum/viewtopic.php?p=808587#808587
Good luck!
Mike the editor
InterVideo Home Theater
By aadis in forum Capturing and VCRReplies: 8Last Post: 4th Feb 2011, 02:55 -
I am looking for nVidia, Sonic and Intervideo codec
By Sean_ve99 in forum DVB / IPTVReplies: 7Last Post: 4th Jun 2010, 03:48 -
Intervideo DVD Recorder in Vista?
By jubbely2 in forum Capturing and VCRReplies: 0Last Post: 13th Jun 2008, 12:40 -
Help, Problem with Intervideo dvd copy 5 platinum
By heman28 in forum DVD RippingReplies: 2Last Post: 3rd Jan 2008, 20:12 -
intervideo dvd
By sumeshkri in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2007, 10:37
