Hi all,
I wondering if someone could possibly help me out I'm fairly new to DVD scene and have read alot of the postings in the forum but I'm still having problems.
I'm using TMPGenc to convert Downloaded AVI's to Mpeg1 - Without using the templates - Works great.
Video Bitrate =
MPEG 1 - 720x480
25fps (pal)
CBR 6000
Audio =
Layer 2
48000khz
192 bps
But when I use MF2 it says the file size is over the maximum size ie 4.95gb
Can somebody plz help me out the settings and a guide on how to do this from start to finish?
1. DVD uses MPEG 2
2. Use a lower bit rate
3. PAL should be set to 720x576
The best thing to do as if your new to this is use the wizard.
It took me a while to get the hang of avi conversion. I follow the following rules (in General).
1. Check the avi properties. If its 25fps convert it to PAL if its 23/29 convert it to NTSC. Most player will play either.
2. Use the wizards and then tweak the settings after. This will give you a better idea of the size of the files you'll get.
2. Alway check the files after encoding to make sure the audio is still in sync
Good Luck -
Thx for the quick reply Tim.
I used the wizard in earlier attempts which worked great till MF2 re-encoded the Mpeg file and knocked the Audio out of Sync half way thru as alot of people have suffered the same problem.
I'm now trying a different software program to burn the dvd which also has a encoder in it as I've been told its very reliable and doesn't effect the Audio, once I've tried this program I'll make a posting to advise people on my finding.
Thx again -
Good Luck with that!
MF2 should not re-encode if it finds a compliant file. The option is in the MPEG setup and should be ticked by default. It even works with audio streams like AC3 as long as it doesn't have to render the file, I saw that in these forum's. Its a great resource to learn from.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
