How do I get a menu setup with VCDEasy? I'd like something that looks similar to how Nero (5) has it set up where I can have a background image, a selection of other images, & even more than 1 menu if possible (an option on the first menu to go to the 2nd, & option on 2nd to return to first). I'm wanting to do this to a VCD. The current VCD is a single MPEG file where I've got chapters set up in it (24 total). I'd use Nero for this since it already has this option but I can only use 15 images & I've got 24 images for the 24 chapters. What file do I edit manually or what option do I use to do this? Again this is only VCD, not SVCD.
Hi, with VCD Easy, you need to build your graphic menu manually.
1. Use a paint program (I've even done it with powerpoint) and produce a single image with the graphics & text you want.
2. Convert it to an mpeg still
3. Make it the first item in your video list.
4. On the interactivity page, overwrite the default assignments.
or you can use tmpg and add an audio loop say about 5 seconds of background music and just tell it to loop in vcdeasyOriginally Posted by stokefan
you can use the jpg and audio and tmpg will make a compliant mpg file for your menu, i just usally put 4-5 chapter pics on each frame and add it in to the interactive part, take a bit longer but works well and i like the music playing in the background,
if its vcd you could try tscv it has a auto generator for menus, but again only for vcd not for svcd
main menue & submenue are not working properly with GFD
By akakiami in forum Authoring (DVD)Replies: 1Last Post: 29th Sep 2008, 07:14 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 21:00 -
How to insert a video in a DVD that have menue without re-processing all?
By whenloverageswild in forum EditingReplies: 0Last Post: 26th May 2008, 08:47 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 16:13
