I hope this fits this forum area since it does concern capture of video/audio.
Been think on this subject for about a week. I check the archive of threads here but found very few thing on this topic.
The basic topic is this. If you even calibrate your setup how do you do it and how do you make sure you start off with a real standard. Can you trace it back to a true standard? This covers both sound and all aspects of video.
Got one idea for color calibration:
(1). Capture a color bar frame through a SVideo cable feeding into the capture at lowest compression and largest rez and save out without any compression.
(2). By digital means capture that same frame without compression.
(3). Load both into Photoshop and compare the values sampling of each color.
(4). If close by eye and sample values then ok.
It pritty crude but basicaly like calibrating a voltmeter. Just bump it againt a known standard.
Try this instead if calibrating colour and brightness is crucial
Joe Kane is a mastor.
http://www.videoessentials.com/index_2.htm -
Good suggestion. Actualy I used that disk for the test.
Had his LD for almost 8 years and the DVD for a few years.
How to calibrate LCD color monitor ?
By SingSing in forum Software PlayingReplies: 2Last Post: 8th Mar 2011, 11:24 -
Was there ever a case where deinterlacing would simply not work?
By mazinz in forum RestorationReplies: 11Last Post: 25th Jan 2011, 05:53 -
How to lighten too dark avi files, simply.
By Hal05154 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2008, 18:17 -
How to Find Someone to Calibrate my HDTV ??
By ofield1 in forum DVB / IPTVReplies: 7Last Post: 18th Feb 2008, 21:54 -
How to simply turn off MKV subtext
By hanugro in forum EditingReplies: 4Last Post: 18th Nov 2007, 04:49
