I followed the guide here on how to turn a divx file into dvd.
It didn't say anything about changing the setting into 2 pass variable bitrate. Would you recommend that or should I use constant bitrate?
When I've burnt svcds I've always used 2pass variable bitrate, but since it didn't say anything about it in this guide, I'm a bit unsure.
What do you say?
nille
Well it a compromise between quality and time. 2 pass VBR will take much longer than CBR with the same avg bitrate, but you should expect better quality video with 2 pass VBR.
Need help to set up Variable Bitrate
By spigy in forum Video ConversionReplies: 19Last Post: 16th May 2010, 14:13 -
Variable Bitrate or Constant Bitrate?
By i am x in forum Video ConversionReplies: 3Last Post: 12th Feb 2010, 08:49 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Variable bitrate Mpeg-2
By miggeth in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jun 2008, 08:58 -
Variable and Constant bitrate ??
By VEBouto in forum Newbie / General discussionsReplies: 4Last Post: 18th Oct 2007, 00:56
