Wow...I actually got Friday AFter Next onto one cdr and the quality is pretty good ...very goodJust happy thats all. Thanks guys 8)
We're always glad to hear some good reports and not just complains 8)
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
I dont really burn to CDR now that I have a DVD burner but I am sure alot of people would like to know what guide did you use or what programs.
SLICK RICK
Originally Posted by lordsmurf -
I did this for experiment only cuz sometimes I think maybe I can make a backup on cdr for the heck of it to watch and don't care if it's dammage since dvdr still a buck or two each these days.
Can you post the settings you used? or the .ini file, or something, so we can see how you did it?
-Yar, matey!- -
How long did this take? I can backup a DVD in less than an hour, from start to final burn. But yeah, CD are cheaper than DVD, and I'd also prefer CD when the content/quality didn't matter much.
get EasyVCD
Rip the file with the VCD Highest quality setting
Ouput to a single mpg file, no mulitiple file
Load tmpgenc select VCD NTSC Film
Non-interlace, 43525 line NTSC
Use Source Range -- Here is where you have to play with the start frame and end frame cut out the parts you dont need. You can watch the space needed to fit on the cd on the Bit Rate setting screen. If it's too much to fit on the cdr, then go back to source range and chop off a little more until you have it fit. Use the time indicator, not the file size. Set your % to about 99% and use the 800min CDR option. On my system with an Athlon 2000+ (1.6gig) takes about maybe an 1 1/2 hour or a little more for ripping and convert. Not all DVD will fit because some are longer than others. I tried with XXX but it's 2 hours long while Friday After Next is only an hour and a half. As well as quality goes, I can tell you it's really nice and your friends won't complain a bit
Good luck!!!
Wow, how hard can it be to just copy a DVD ?
By liffy99 in forum Newbie / General discussionsReplies: 16Last Post: 6th Feb 2009, 14:32 -
haha, wow, it echoes :P
By eccentricity in forum MacReplies: 5Last Post: 13th Dec 2007, 10:18 -
WOW its gettin hot
By Heywould3 in forum ComputerReplies: 14Last Post: 6th Nov 2007, 19:10 -
Wow I found you guys
By alanr in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2007, 16:27 -
pc reboots when wow starts up
By Mr anderson in forum ComputerReplies: 8Last Post: 26th Aug 2007, 08:01
