  1. i have a sony dvp pq1 dvd player....... it plays vcd and svcd with header trick...............i took my video and mounted on damien so its in mpeg2 format..i then use nero to reencode and burn.... came out fine but audio comes after they move their lips.... so i tried the header trick and then burned it with nero sound and picture look good but now i got green shit on top and bottom of screen ... so if any1 can steer me so i can get it with no green shit and the audio to be right with the video. btw i used tmpeg to try to make the mpeg2 to a mpeg1 but it wont let me open the file in tmpeg
    thanks in advance
  2. Well I've heard that Nero's encoder is one to avoid. Try using TMPG to encode your mpegs but if you need to convert an mpg2 file that you're satisfied with (picture and sound are ok), you need to place the mpg2 plugin for TMPG into the TMPG folder. TMPG will open mpg2 with the plugin.
    Get it HERE.
    You need something like WinRAR to unpack it.
    Hope that helps.
    Happy to be here.
