I've been wanting to burn some m2v files but my problem is with the file itself. When I watch the video it has this little box that runs around the screen. I'm guessing it maybe a coding problem but I figured I'd ask and see if anyone knew. and if so what can I do?? its a little white box with like 9 squares. Hope somone can help meThx
everything runs fine..I have image...the whole thing runs its just that there's a little box moving around while the file is running.
Is the box part of the video? I mean, if you advance it frame by frame, is the box in most of the frames?
Hello. -
not apart of the video...its pretty much in there the whole time..all it will do is move around the screen...I downloaded another m2v file and it worked fine..the only difference I saw was that most of the files are about 70 to 100 mb big and the one that's working without the box is about 58mb
crop m2v video file
By robbtek in forum Video ConversionReplies: 3Last Post: 17th Feb 2011, 10:58 -
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 06:17 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
How to reverse a M2V file
By lorix in forum EditingReplies: 2Last Post: 13th Nov 2008, 04:09 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
