    Jun 2001
    Richmond , VA
    Does anyone know of a easy way to remove dead links from a menu ? I have some back-ups where I have removed the full screen version of the movie and would like to elliminate the the menu link .
  2. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    So, what do you want your final result to be?
    MOVIE ONLY?
    MOVIE WITH MENU OPTIONS BUT WITHOUT MENU?
    SLICK RICK
    Nobody likes a bunch of yackity-yack.
  3. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    Slick -
    I believe the original poster is removing extras, and he wants to remove the menu option that says "extras" from the list of menu items, instead of leaving a dead button that doesn't link to anything.
    The short answer is the only way to really do it is to rip and re-author the whole thing with a new menu. Most other methods leave you with a dead link on the menu.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  4. Member SLICK RICK's Avatar
    Mar 2003
    Thanks housepig,
    Now that I read it a little closer, that sounds exactly right.
    Well, vtecwil, the only option I can think of is the one housepig already stated. Reauthor a whole new menu.
    SLICK RICK
    Dec 2002
    The Great Northwest
    Menu edit and/or IfoEdit.
    I think you are talking about removing the link to a full version of same film on same DVD [RE: 16:9 and 4:3] on same DVD. Isn't that a dumb idea, I use IC7 for most of these because if you eliminate one version it is under the 4.38 and thus fast but you have to remove the other version link in the menu and change the call in the .ifo to actually call the version you kept to make them work and look correct.
    I have found if you do not do this and just hit play you will just get a loop and the film will not work properly. If you do not want to do the modifications. I have found if you >select chapter selection >chapter one>play>then version it will play correctly, as a work around.
    hope this helps
    Dd
    Menu Edit
    http://menuedit.dimad.net/home.html
    IfoEdit
    http://mpucoder.kewlhair.com/Derrow/
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
    www.dvd9to5.com/forum/
    "For every moment of truth there's confusion in life"
    Black Sabbath/Ronnie James Dio
