i loaded a dual-audio avi file...want to convert it but cant seem to figure out how extract the audio sound track i want...it is there cause i found a player that will play it...how can i seperate the 2 sound files so i can use the one i want
thank you
ted
Try to load it into Goldwave. It may be each channel carries a different track.
Hello.
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 15:17 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 05:53 -
Dual audio streams in an AVI file
By edwardcr in forum Newbie / General discussionsReplies: 3Last Post: 19th Dec 2010, 08:33 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 13:40 -
burning a dual audio file
By imkool in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2007, 05:30
