  1. Ok, heres my problem, I used to have Win2k on this machine along with FireBurner. I used to beable to burn the .bin fles and .cue files fine.. so I got XP.. and all .. instaled it. OK.. now I went to teh fireburner website.. got the new fireburner for XP.. Now.. when I burn teh .bin and .Cue files.. it doesn't work in my DVD player. It worked before on WIn2k?? ANyone got an idea??
    VCDer (trying)
  2. You could try Nero
    Its a free download and seems to be able to burn almost anything.
  3. LINK?
    VCDer (trying)
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    cdrwin 3.9x - THE program for burning cue/bin files
    http://www.goldenhawk.com/
  5. I suggest you try CDRDAO / VCDEasy. This works with most modern burners if you have the ASPI layer installed correctly.
    If that fails, CDRWin is good too.
    Nero can burn CUE/BIN images mostly properly but it still doesn't burn subindicies (last time I looked -- don't know about now).
    IMHO, if CDRWin doesn't work, you should mount your CUE/BIN image using Daemon-Tools as a virtual CD and then use CloneCD to copy it.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  6. Член BJ_M's Avatar
    Jul 2002
    Canada
    Daemon-Tools is one great program -- anyone ever had system instability problems though after installing it ? (i had the first ever blue screen in XP during its installation in fact - though a second attempt went fine) ..
