  1. hi ive got an avi encoded in divx5.05 with ac3 sound and i want to frameserve thru tmpgenc but when i try to open the vdr in tmgenc it says it cannt open or unsupported. My xvids work fine but its just the divx5 avis that dont work
    can ne1 help?
    Apr 2002
    The State of Frustration
    Is DirectShow set as the highest priority?
    Hello.
  3. Originally Posted by Tommyknocker
    whats the highest setting? I had it set to 2 originally
    Apr 2002
    I meant of all the open sources, DirectShow is the highest. a setting of two is fine, if all the others are lower than two.
    Hello.
  5. Originally Posted by Tommyknocker
    in that case yes!
  6. Member DJRumpy's Avatar
    Dallas, Texas
    Ensure that you have all of the necessary video, and audio codecs to properly decode the DivX. Use GSpot in the TOOLS section to open your AVI, and verify. It will tell you if everything is installed and working properly. Simply being able to play back a Divx doesn't necessarily mean you have all of the necessary codecs installed.
    Impossible to see the future is. The Dark Side clouds everything...
