Hi all I just wanted to post this to all that have been having problems with Sony DRU500. When I first bought the drive I was having lots and lots of problems burning DVD-R's but DVD+R's were ok. I called Sony and all this time I was thinking it might be a media problem. I think I bought every type of DVD-R Media out there with no luck. This is what I was running in my computer at the time.
AMD 1900+ Windows XP without the SP1
DVD-ROM, Two CDR burners, 512 DDR Ram 2100,
5 internal and 1 External Hards Drive totaling 740 Gigs
yes I know its alot. ATI AIW 7500 Video Card and
5.1 SoundBlaster Soundcard.
Anyway I had a bad crash on my Operating System Hard Drive which I had to reformat and reinstall XP. Well at that time I had the XP with the SP1 already in the install disk so I use that one instead of the reg XP w/o SP1. Well after all was install low and behold my DVD burner was now burning DVD-R even ones that were not suppose to work with Sony were working. And at 2x all of them. At the time I had Firmware 1.0d so I wanted to test one of the older firmware and see what happen so I went back to 1.0a and still it was working with every DVD-R I throw at it. Now I'm at 1.0G so if you guys with this problem this might work for u too. Good Luck All. Hope I help![]()
Results 1 to 1 of 1
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 19:41 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Wedding Videography Sony HDC 900 or Sony PMW EX3 ? Tapes?
By mek in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Oct 2010, 14:35 -
Sony TVR-460 with FireWire cable 4pin undetected by Sony Vaio Laptop
By vatsyk in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2009, 18:45 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00
