  1. Hey There,
    I was wondering if anyone could help me out. Im trying to backup my Die Another Day special features disc and im having problems. Since its a dvd-9 Do i use the same process by going through dvd2one? treating it like a movie? I tried it twice and no luck so far! If anyone could help me out that would be great. I havent yet come across a special features disc thats not a dvd-5
    Thanks, Looking forward to hearing from someone
  2. If you want a complete back-up just use dvd2one version 111. Select in copy mode full disk. Or use dvdshrink, it's easy and free. Not as good as dvd2one, but good quality.
    http://www.dvdr-digest.com/software/software.php?file=dvdshrink
  3. Hey There,
    Thanks for the reply but here is where im having my problem. I use Dvd Decrypter to download the files to my harddrive. From there I use DVD2One and choose full disk just as I do for all the other backups. It does its thing and from there to burn the dvd i use CopytoDVD. It fails everytime! Now my question is...is Copyto DVD not the best program to use? is that where the problem is taking place? or is the problem happening during the DVD2One portion of disc backup?
    Thanks again...Looking forward to hearing a response
  4. Member tumbar's Avatar
    switch off and try nero....
    I've had problems with copy to cd burning on some disks. I burn the same files in nero and it works fine....try wuth a re writable if you don't want to risk a disk...
    Jim
  5. VERY PROBLEMATIC DISC....
    DAD is dual-angled....
    if you go into main menu, and find ur way
    the is a MI-6 thingie, that lets u see making
    of stuff and info boxes how things are made
    there, use dvd2one, choose movie only
    make sure you get right audio, if you go full
    disc, make sure you choose correct audio
    streams there also, hope it helps....
    Mar 2003
    France
    i recently backed up my copy of die another day special features disc using dvd2one and recordnow max, worked fine in all my players.
